Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 04-16-2010, 08:32 PM
dannymoz71 dannymoz71 is offline
Send a message via Yahoo to dannymoz71
Wont Start, Need help.
I replaced the intake gaskets on my 98 Tahoe with the 5.7L in it today and now it wont start up. Im assuming I messed up the timing when I pulled the distrubutor when I pulled it. Everything else seems to be good. The distribtor needs replaced anyways means it has a broken ear and wont hold the cap properly. How do I get the timing right again? Im heading back to Iraq of R&R in a few days a need some help. Thanks.
Shane
'05 Z71 H.O. 5.3
Flomaster muffler and custom dual exhaust, Volant cold air intake, Dual Optima Batteries, Edelbrock Headers. Back in Iraq again.
Old 04-16-2010, 10:45 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Wont Start, Need help.
Make sure the #1 cylinder is at top dead center. With the spark plug out you should feel compression out of the hole with you finger as you turn it over by hand. If you don't feel compression your on the exhaust stroke and you'll need to turn the crank another 180 and then line up the timing mark on the crank pulley.
Drop the distributor in so that the rotor is pointing as close to the #1 wire as possible.
Old 04-16-2010, 11:19 PM
Scrapper Scrapper is offline
AF Premium User
i agree with what was said earlier but suggest taking it to some one else to do
Old 04-17-2010, 08:33 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
HERE IS FIRST THING TO DO.
http://files.automotiveforums.com/ga...hp?photo=51302
Second step after it starts and runs is to get it on a engine capable scanner and check/set camshaft retard.
MT
