Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 04-16-2010, 04:45 PM
y13supio y13supio is offline
what else should i replace while doing timing belt
92 camry 2.2 dual overhead cam. i replacing the timing belt and front crank seal tonight, is there anything else i should replace while i'm doing that?
Thank you, Jon
Old 04-16-2010, 09:26 PM
1965pravin 1965pravin is offline
Re: what else should i replace while doing timing belt
Thank you, Jon
oil seal, cam seal and check the water pump
Old 04-17-2010, 12:41 AM
thank you 1965pravin.
Old 04-23-2010, 08:46 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
How many miles?
Agreed, consider a new water pump if the miles are way up there..around ~200k. Mine was fine and not leaking after 207k, but I figured if I had it apart I might as well...felt I'd be tempting fate if I didn't. Just make sure you get a good brand...OEM would be best since it has a good stainless steel impeller...mine was still new and shiny when I pulled it. Most parts stores and eBay sellers have a cast iron impeller which will take more care to keep the coolant from diminishing in corrosion protection.
I'd also consider replacing the idler pulleys along with the aforementioned crank, cam, and oil seals.
Finally, buy a valve cover gasket set if it hasn't been changed out recently. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
