Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 04-13-2010, 11:28 PM
BIGP19 BIGP19 is offline
Question Crown Vic code P1299
i got a 98 police interceptor Crown vic and my car acceleraed sluggish then he temp needle hit the H...i added sum antfreeze i was good then it did it again advance auto gave me da 1299 code and i let my car shit for 2hours unhooked he battery because i was hooking up subwoofers.now he check engine light is off and i drove slow home and it didnt happen ..soooo is this temporary? or will it happen again??
and also i have no leakage anywer
pete
Old 04-14-2010, 06:30 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Please Help Engine Code:p1299(lincoln Lsc)
Welcome to the forum!
Have you checked the coolant level again? There may have been an air pocket in the system last time that only allowed you to add so much coolant, now the air pocket has worked its way back to the top and the level is low again. You could also have a heater core leaking and you don't see the leak.
If the coolant level is still full you should move (or have me do it) your post to the Crown Vic forum.
-Rod
Old 04-14-2010, 06:43 PM
yea i did no leak n i had a dianogstic n he said dat my computer to my car was showin 40 below so the fans wouldnt come on so now im fina pay 517$ for a new computer+flash is he tryna play me? it kinda mak since tho
Old 04-14-2010, 09:34 PM
shorod's Avatar
SHO No Mo
Wow, is that English?
If the computer is showing 40 below, how did he rule out the Engine Coolant Temperature (ECT) sensor? I'd really struggle to suggest jumping to the ECM and flash. There are a lot of relatively simple diagnostics that could be performed on the cooling fan and ECT sensor.
You're question really isn't related to the Lincoln LS though so I'll move it to the Crown Vic forum.
-Rod
Old 04-15-2010, 11:42 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: Crown Vic code P1299
Replace ECT sensor. It's a cheap enough part. Also check for wire continuity from the ECU to the sensor (get a multimeter if you don't have one, they help in so many ways).
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
