Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 04-14-2010, 07:36 PM
killertk5 killertk5 is offline
95 Lebaron troubleshooting
ok so i recently bought a used 95 chrysler lebaron and has 150k miles. i started it up fine and bought it after test driving it. on the way home it stopped. i had to pull over and it hasnt started since. the engine turns over but does not start. i have replaced the spark plugs, rotor, coil, and distributor. but it is still not working. we think its electrical since the engine turns over. please please please someone help!
Old 06-23-2010, 02:28 AM
CoachKarl CoachKarl is offline
Re: 95 Lebaron troubleshooting
Old thread. Did you fix the problem?
If the car still sits idle, how about your fuel pump?
The Lebaron, when the ignition engages, should make a 1/2 second "whirring" noise. That's the fuel pump. If it doesn't make that noise, have an assistant throw the ignition back and forth while you "spank" the gas tank. If the car starts, replace the fuel pump . . .
We're all in this together. . .
