Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 04-14-2010, 05:09 PM
mondow mondow is offline
96 chevy burb missfire
Helping with my son's burb.
#1 Blown head Gasket-Had it replaced.While torn down cleaned fule injectors as they wher coverd in black grunge.Put it back togather and
obd scanner said roter error replaced roter and cap with new one
#2 scanner says miss fire in #6 cilender-now after a week of bumping heads togather i came here.The truck ran fine up till now.
now it idle's fine with slight miss but when you put your foot into it it bogs down and run's like sh----t.
Any help or sugestions whould be happy to recive.
I dont know much about newer cars.As i have a 89 mustang,89 camaro
68 firebird.all cars i can work on without all the scanner stuff.
thank's for any help in advance.... mondow
the code number is 1345
Old 04-14-2010, 06:20 PM
777stickman 777stickman is offline
Re: 96 chevy burb missfire
Welcome to AF.
Need all the code numbers to be able to further help you.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 04-14-2010, 08:58 PM
the code number it read's 1345
Old 04-15-2010, 08:28 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Code 1345 is Cam and crank sensor correlation.
Crank/cam sensor correlation known as camshaft retard will have to be set on a engine capable Scanner that will read out camshaft retard.
If you do not have one borrow or rent one or find a repair shop that does
Needs dist turned until the camshaft retard reading is as close to 0 degrees neg or post as you can get it.
Let us know how it goes.
MT
Old 04-15-2010, 08:33 AM
MT-2500's Avatar
AF - Advisor
But
First make sure you have the dist set right.
http://files.automotiveforums.com/ga...hp?photo=51302
MT
