Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 04-14-2010, 10:00 AM   #1
Thatguy85
Exclamation 98 lumina won't crank
Hello all,
I'm trying to help my friend who know's little to nothing about cars, and does not have the money to pay a 'real' mechanic. Soo this is where I come in.
It's a 98 lumina, and it will not crank. Obviously our first thing to try was to jump the car, however when we tried that the car still would not turn over. There was no audible 'click' of the starter trying to turn the car over, not even the headlights or hazard lights would come on. The only electrical things in the car to work were the door chimes, and the electric seats.
Okay, so it has to be a fuse, right? We checked every fuse in the car, not a single one was fried. I really have no way of checking if any of the relays are bad, like the ignition relay, etc.
My only possible thought is that:
1) The ECU is bad
2) There is a loose or corroded ground wire somewhere
3) Isn't there a chip in his key or something? If that went bad, would that cause all this trouble?
Any help is GREATLY appreciated!
Thatguy85 is offline   Reply With Quote
Old 04-14-2010, 11:30 AM   #2
Airjer_
Airjer_'s Avatar
Re: 98 lumina won't crank
Did you check for power at the fuses. I think the first one I would check is the ignition switch 1 maxi fuse.
Airjer_ is offline   Reply With Quote
Old 04-14-2010, 11:46 AM   #3
Thatguy85
No, I didn't have a meter with me at the time. I'll try to check that out though next time I go over to help him. Any other ideas?
Old 04-14-2010, 12:49 PM   #4
maxwedge
A990 racer
Confirm 12v at the solenoid when attempting to crank. Does the security lite stay on?
maxwedge is offline   Reply With Quote
Old 04-14-2010, 04:43 PM   #5
kevinb70
Send a message via AIM to kevinb70 Send a message via Yahoo to kevinb70
to add to max's comment
can try another key or wiggle while trying to start... perhaps the contacts which connect to the resistor built into the key are not making contact.
check grounds, and there are TWO fuseboxes in the engine compartment, one inside the passenger area on side of dash.... id look more into the two in the engine compartment.
2 fuseable links near the starter
regardless of a security issue, you should still have +12V at the starter (big wire) where you can use a screwdriver to jump the starter solenoid (short small bolt to the large bolt)
make sure the A/C is OFF... otherwise you'll have the electric fans coming on if it starts.
kevinb70 is offline   Reply With Quote
Old 04-14-2010, 07:15 PM   #6
maxwedge
A990 racer
Kev, no fusible links at the starter on this newer Lumina, good added info though.
Old 04-14-2010, 08:49 PM   #7
kevinb70
saw them when i was doing the top end, my lumina is a 98
diagram from alldata
irrelevant tho, checking where they go..... one goes to the alternator the other the rest of the power dist boxes, so everything would be dead if the 2nd one were burned out.
Old 04-15-2010, 10:49 AM   #8
Thatguy85
Interesting. Pretty much everything IS dead in the car. Looking at the wire that goes to the power dist boxes, where is the fuse? Is it an in-line fuse, or would it be in a fusebox?
I appreciate everyone's responses, you've been very helpful. I'm going up saturday to give it a shot.
Old 04-15-2010, 10:00 PM   #9
kevinb70
2 fuse boxes in the engine compartment, on each side, under or near the diagonal frame braces. driver side near washer fluid reservoir, passenger side underneath the diagonal frame brake. you can pop that cover off without removing the brace
check each one for 12v with multimeter or test light
what else works? cigarette lighter, dome lights, brake lights, parking lights, horn, etc... does turning the key to on position give you any dash lights or anything else come on?
Old 04-17-2010, 01:21 PM   #10
Thatguy85
absolutely nothing else comes on. Door chimes, and then when I push a switch on the power seats, they go off.
Horn doesn't work, dash lights, dome light, etc etc.
Checked power to fuse box near battery and passenger side, both only getting about 1v, same with the power wire to the starter.
Checked the battery, appears to be charged.
I'm here now trying to fix it so any quick replies are very much appreciated.
Old 04-17-2010, 01:25 PM   #11
maxwedge
A990 racer
Still sounds like a bad ground or battery connection bad. Have you checked for full 12v in the large fuses in the under hood box?
Old 04-17-2010, 01:29 PM   #12
Thatguy85
IGN SW 1 fuse gets 6v
Checked a fuse on the passenger side, it was 60A, and only got .5v there.
Ughhhh.
Old 04-17-2010, 01:38 PM   #13
Thatguy85
Took a jumper cable, hooked one end to the + battery post, touched the other to the starter. I hear an audible click coming from both fuse boxes, I can hear something else turning on, can't tell what.
There definitely has to be something wrong with the grounds in the car me thinks...
Old 04-17-2010, 01:43 PM   #14
Thatguy85
Old 04-17-2010, 01:45 PM   #15
Thatguy85
Ok, tried something that may not have been smart.
I attached the jumper wire from the + batt post, then clamped the other end on to the starter + post.
When I did this, flashers came on, everything else in the car came on.
Then I tried to start the car. Heard clicking, rattling, car didn't start. Tried it again, same thing. Once more, and then I got nothing. Maybe I just made the problem worse....
