Go Back   Automotive Forums Car Chat > Ford > E Series
E Series Forum covers questions and discussions regarding Ford E-150, Ford E-250, Ford E-350, and Ford E-450.
Old 04-13-2010, 05:39 AM
9breeze 9breeze is offline
2000 E-350 5.4L Trans problem.
First off the van will not stay in park and I assume this is a linkage problem. I hope anyway. The other day someone was playing with the fuses and now the radio will not work and the van will not start at all. I hooked up a jumper switch and it works so I hope this has to do with the switch. Can anyone send me the fuse diagram so I can figure out what was put in the wrong way. I do not have the manual for this and have googled it with no luck. Thanks Sean
Old 05-19-2010, 09:08 PM
WilleyB WilleyB is offline
Re: 2000 E-350 5.4L Trans problem.
Are you still looking for the fuse layout and identification? I have a 2000 E350 with a 6.8 Probably most of the wiring is the same. If you still need it I'll scan the info and post it for you.
Cheers
Willey
2000 E350 Super Duty Triton V-10 Motor Home
2005 Pontiac Sunfire
