Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 04-13-2010, 04:06 AM
rafaone rafaone is offline
Exclamation Change Oil Transmission and remove seal Filter!!
Hello there,
I got a Tahoe 2001 Z71, and I was tryying to do the whole maintenance regarding differentials, transfer case and transmission, but there I found two difficulties, first to pull out the oil pan, and second to remove seal filter, can somebody help me out to solve this ??
Thanks Rafaone
P.S. The Transmission that I have there is a 4L60E
Old 04-13-2010, 10:34 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Change Oil Transmission and remove seal Filter!!
Originally Posted by rafaone View Post
Hello there,
Thanks Rafaone
Filter seal can be remove with a sharp chisel from side lip.
Mash seal in without cutting transmission housing.
And drive new seal in with a 7/8 -15/16 socket turned upside down.
Always use the hard rubber rubber gasket for pan gasket and correct fluid new GM in transmission and transfer case fluids and right rear ends oil.
Some times transmission ha to be raised up in rear and or cross-member slid back to remove transmission pan,
MT
Old 04-13-2010, 10:51 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Not sure exactly for your truck, but as I recall there are isues with the shift linkage clearance (on older models...yours would likely have an electronic shift module) and also you may have to move the rear transmission support crossmember aft a few inches to get the pan to clear the valve body inside.
The tranny fluid filter should just pull straight down and out of the valve body...you might need to twist & pull to get it loosened. The filter seal that is driven into the valve body is a PITA to remove if it has been driven flush to the body. You'll need a hook-type seal puller (I've used a hook from a 3-jaw puller and a screwdriver through the hole as a two-handled hook...and alot of yanking. A slide hammer with hook attachment would do it much easier if you have the underbody clearance.) to pull it down & out enough to collapse it with a screwdriver to the edge. Just be careful to not score the body's seal wall with the hook. When you drive the new one in, leave the seal lip slightly exposed (1-2mm) so you can skip the yanking and simply collapse it.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
