Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 04-12-2010, 06:23 PM
bratt bratt is offline
Cool fuel pump has no power 96 dodge ram 5.9l
the fuel pump 30amp fuse blew on this 5.9l gas dodge ram here.
when i looked at the fuel pump i see no power coming to the connector with the key on or key start.
I swapped out the blown fuse and it good now. The fuel pump relay I swapped out too.
I heard there might be a second fuse some where?
Old 04-12-2010, 07:10 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: fuel pump has no power 96 dodge ram 5.9l
I don't know of a 2nd fuse. The fuel pump only runs a few seconds with the keyswitch On unless the engine starts then it'll stay on. Are you checking the power at the fuel pump?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 04-12-2010, 08:17 PM
yes I am checking power at the fuel pump.
I might not have a good ground on my test light.
I tested power at the fuel pump fuse and i saw power. I also saw power on one leg on the fuel pump relay.
is there something I can do to test the connector to make sure the fuel pump is getting power before I buy another fuel pump?
Old 04-13-2010, 02:11 AM
AF - Advisor
You might have an assistant turn the keyswitch on while you're holding your testlight on the positive wire on the connector. It should come on for a second. It needs to be the pump wire and not the fuel level sensor wire.
Old 04-13-2010, 10:23 AM
yes I did that and I see no power
Old 04-13-2010, 07:17 PM
AF - Advisor
Because a fuse was popped makes me wonder about a possible short between the relay and the pump. If the short was stout enough, it may have burned the wire in two or melted a wiring connector/splice, opening the circuit.
You might run a wire with an inline fuse from the battery to the fuel pump just to test if the pump will run...be careful.
