Go Back   Automotive Forums Car Chat > Buick > Century
Old 04-11-2010, 12:12 PM
manicmech manicmech is offline
'93 3.3 rough idle, stumbles off-idle
I have a '93 Century with a 3.3 V-6 and 94,000 miles. It idles a bit rough, but stumbles really bad on acceleration from a standstill. Higher speed acceleration is normal. I got a code for a lean condition (44 I think it was). I replaced the fuel filter, air filter, and oxygen sensor with absolutely no change. It also has relatively new plugs and wires. I have about 35 psi of fuel pressure at idle. I do not have specs as to what this should be, but I thought it might be a bit low? Can anyone confirm what it should be? Could it be a MAP sensor? What else can I check? Thanks for any help you can offer, as my knowledge is mostly on older vehicles.
Old 04-12-2010, 12:42 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: '93 3.3 rough idle, stumbles off-idle
Your symptoms are consistant with a bad MAF (Mass AirFlow sensor), but low/borderline fuel pressure can exhibit the same.
35psi fuel pressure is right at the low end of acceptable. The pump specs are 51 psi max, and on-car it should read 41-45 psi key on/engine off, and should drop 3-7 psi engine running with vacuum attached to regulator. So if you take the low KO/EO reading and subtract the max vacuum drop, you get 34 psi. Taking into account a margin of error on your gauge, you could be below acceptable pressure and in need of a fuel pump.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-12-2010, 09:18 PM
Scrapper Scrapper is offline
AF Premium User
check your tps see if it's bolts came loose or need a new one.
Old 04-13-2010, 05:05 PM
Thanks for the tips. I removed the MAF sensor, cleaned it, and reinstalled it with no change. The TPS is not loose. The fuel pressure with key on, engine off is 37 PSI, so I suspect it may be the cause.
Old 04-13-2010, 09:12 PM
AF Premium User
yes time to drop tank.
Old 04-14-2010, 04:09 PM
richtazz's Avatar
if ko/eo pressure is only 37 psi, then most likely the fuel pump needs to be replaced. It's only 4psi under minimum spec, so if you're using a cheaper/high usage pressure guage, it could still be the guage that is off but not very likely.
