Old 04-11-2010, 11:01 AM
a_alyte a_alyte is offline
Another gas mileage post
2000 GT w/160K
I've been dealing with the terrible gas mileage issue for some time now. I regularly take a 150 mile highway trip using cruise control (70-75mph) & have been burning a 1/2 tank of gas. This is ridiculous considering the Jeep & Avalanch I also drive use a 1/4 tank for the same 150 mile trip!
In the past year I've changed the fuel filter, fuel pump (Ac Delco), rear 02 sensor, k&n replacement filter, pcv, top intake manifold & water pump. Yesterday I decided to replace the spark plugs & wires & installed Ac Delco platinums. A few hours after dropping the new plugs in, I took the same 150 mile trip & realized my mileage was even worse! When I got to my destination I had between 1/2 & 1/4 tank which is even more ridiculous.
My car drives & handles fine otherwise & I'm running 30psi. Would iridiums make much difference?
Old 04-11-2010, 04:38 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Another gas mileage post
While you are cruising at 70mpg with cruise control set what are your RPM's at?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 04-11-2010, 07:21 PM
Rpm's are at 2k if I remember correctly. My temp is a 1/4 of the way up when cruising & gets close to the 1/2 when sitting in city traffic.
Old 04-12-2010, 08:29 PM
tblake's Avatar
In God We Trust
2k RPM's at 70mph sounds normal. Anything higher than that and I'd suspect a trans issue either torque converter slippage or a stripped 4th clutch shaft.
Although 150 miles out of a half tank does seem rather on the high side, it doesn't seem terrible for. Next time try the trip at 60mph instead.
And after you drive your car next time, get out and feel the wheels, do any seem hotter than the rest? Maybe you have a dragging caliper.
Old 04-12-2010, 09:43 PM
I swapped the platinums for iridums now I'm back to using a 1/2 tank for 150 miles of highway driving. I guess I consider a 1/2 tank to be terrible cause I'm comparing the trucks I drive which only use a 1/4 tank. I'll check the wheels for any abnormal heat. Thanks for the feedback.
Old 04-13-2010, 10:35 AM
tblake's Avatar
In God We Trust
yeah, 150 isn't great by any means since your car is Naturally Aspirated. But there are many factors to take into consideration (wind, speed, traffic, stop lights, hills....)
When you took your first set of plugs out, what did the tips look like? Were they wet with gas, or covered in dark colored carbon buildup?
Next thing I would do is remove the IAC motor and clean it and its bore with carbon cleaner. Then take the MAF off and use MAF sensor safe cleaner on it.
Then I would remove the vacuum line off the fuel pressure regulator and check for fuel contamination. With the vacuum line on, turn the key to run so the fuel pump primes then check to make sure there is no gas in the vacuum port.
Other than that, you can check to make sure you have proper fuel pressure and that it holds. My GTP last summer was running rich (via scan tool), It turned out the be a leaky fuel injector.
Old 04-13-2010, 11:37 AM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
you could also try putting a can of seafoam in the gas tank to give the fuel system a good cleaning.
Old 04-13-2010, 12:42 PM
rkvons's Avatar
rkvons rkvons is offline
I would also not rely on the gauge to tell you how much gas you are using. Fill the tank, go the distance, fill it again and see how much you used. Your gauge might be coming down too quick.
Old 04-13-2010, 12:51 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
1/2 tank for 150 miles is not so bad. It means 18.8 mpg in highway. For a Grand prix with 3.8L engine and 160K miles it's reasonable. Better than my Windstar.
Don't compare with your Avalanche cause this one have a 31 gallon fuel tank so you have same fuel consumption. It's bigger, but better engine technology with direct fuel injection and 6 speeds transmission. And it's newer.
Normally, used vs new plugs don't make a big difference in fuel consumption. If the old one was working, new can improve to 0.5% only. Maybe the AC delco was very bad designed, it's strange.
A tips to improve gas mileave, draft semi. It reduces air drags a lot.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 04-13-2010, 01:03 PM
doctorhrdware doctorhrdware is offline
I can get close to 400 miles out of a tank of gas with my GP SE 3.8 L. That is an average of 60 Mph. With some stop and go traffic in the mix too.
In the Chicago area the semi truck drivers are too crazy to follow. Plus with all the construction on the expressways, speeding in the construction zone the first offence will cost you $510. The next offence will be $1020, and the third offence is automatic supension of your DL for 1 year.
Old 04-13-2010, 01:10 PM
troy1 troy1 is offline
AF -Advisor
Possible bad lower intake manifold gaskets. None of your brakes are dragging and your tire pressures are correct?
***Also I see you have a K&N clean your MAF sensor with some MAF sensor cleaner and see if that helps. Oil from the K&N is bad for the MAF it distorts the readings when the wire get oil on them
Old 04-13-2010, 01:49 PM
i was also going to suggest that, however noticed that the OP has a K&N drop in replacement filter therefore shouldnt really be oiling that (but then again, K&N does suggest oiling after cleaning) . IMO K&N is useless, and alot of people on this forum would agree that a good replacement Delco filter will actually do better than a K&N. again...just my
Old 04-13-2010, 02:00 PM
When I took my old plugs out they all looked the same with a little white & no signs of oil/gas etc. I recently placed a can of seafoam in the gas tank & also cleaned the throttle body. I'm not sure if my lower intake manifold is leaking or not. I knew my top one was because it's easier to see! My tire pressure is 30 psi all around.
I'll give the IAC & MAF sensors a cleaning and go back to calculating my mileage (instead of using the gauge only.) I'll have to check my manual regarding checking fuel pressure & removing the vacuum line since I've never done this before.
I appreciate the tips
Old 04-13-2010, 02:39 PM
The white plug was probably caused by the intake leak or misappropriate plug heat range.
Old 04-13-2010, 06:26 PM
BNaylor's Avatar
BNaylor BNaylor is offline
That is very bad gas mileage for any GM car with the Series II 3800 engine. My wife's '99 Regal (Naturally Aspirated) gets 26-28 highway and my '97 GTP (Supercharged) used to get up to 30 mpg highway before the engine mods. Cruising at 70 mph.
Timeslip 08/12/06
AF Community Guidelines
