Go Back   Automotive Forums Car Chat > Buick > Regal
Old 04-11-2010, 10:54 AM
mikesmith20001 mikesmith20001 is offline
No key return & immobolizer
Hello,
I'm having a problem with my 2001 3.8L v6 Regal.
A few months ago it started not allowing me to take the key out once i switched it off.
I was working around it for a while by pressing the brake a few times, then listening for the relay click, then the key would come out fine.
A few more weeks went on (i know i got lazy, but i do all my own work on it and did not have time), and even the pressing brake pedal work around stopped working. I then found pressing the push down switch on top the gear shift a few times also made whatever relay click and allow me to take the key out. Then even that work around stopped.
A few times i found myself needing to get out the car and not being able to take the key out, so in my hast i yanked the key out. When i returned i started it up again and switched it off by waiting for the click and all was fine, except it would not give me the key back every time.
To cut a long story short, that went on for a few months. My wife goes to start it this morning and the car gives nothing, no lights, no clicking.
I think by pulling the key out etc i damaged the immobilizer, as the battery is new (less than 2 months).
Is there any way i can bypass the immobilizer?
The car is not the primary and is only used for dropping/picking up kids and grocery shopping.
Thanks,
Old 04-11-2010, 03:00 PM
Re: No key return & immobolizer
Just did some more diags and thought i should update.
Battery is showing 2.8 volts. Cabin lights arn't even working.
Wife also said it refused to give her the key back a day or two ago and she pulled the key out by force. The ignition was on stage 1, with 3 being when the engine starts.
Not sure if the battery is faulty or a result of the car being left with ignition on 1 for two days.
Does the ignition on 1 use any current?
Any ideas guys?
Thanks in advance.
Old 04-11-2010, 10:44 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
In my car, it doesn't use current in stage 1. It just unlock shifter and steering. It's mechanical.
But in yours, I think the relay use current in stage 1. About 150mA. So yes, it's the cause of the discharged battery.
I think I know what is the problem. It's the steering lock mechanism. Try to turn the wheel while turning off. Or a problem in the park lock mechanism. Put it in park completely. If it doesn't help, you need to replace the ignition cylinder.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
