1997 pontiac gp a/c relay
yes, i tried to start a/c other day and clutch will not start. took plug of ac compressor and used test light with a/c controls on and fan on high and no power at this plug. what could be the problem a/c relay? and if so how do you test relay if it is bad.
Re: 1997 pontiac gp a/c relay
Low Refrigerant. If refrigerant is low, the ac clutch will not be commanded on by the PCM. See if you can get your high and low side pressures checked.
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
