Go Back   Automotive Forums Car Chat > Subaru > Impreza/9-2x/Outback Sport
Old 04-10-2010, 12:48 AM
mehrshadvr4 mehrshadvr4 is offline
MBC on stock 02 wrx
so i had a question about using MBC on a stock 02 wrx. the car has catback and cold air intake. the thing is i searched and installing mbc on a stock ecu wrx with no engine management is too risky. is this correct? i read on the net that some people run mbc on stock wrx and are fine, they say anything below 17psi is fine, but some say the ecu will not adjust to the extra boost given to it which is not good at all. to be honest i never thought ecu would do such thing. i came from 3000gt platform and on these cars all you need to do is to add boost till about 14 psi before you run lean on stock fuel system. the ecu adds fuel and adjust timing for extra boost, but if wrx is not going to do this then i guess leaving it at stock boost is the only way.
Old 03-19-2011, 03:23 AM
mmcleo11's Avatar
mmcleo11 mmcleo11 is offline
Re: MBC on stock 02 wrx
The stock ECU can be reflashed and it can increase boost via the ECU. Will run 17psi boost on stock engine all day without issue
N14 Pulsar
VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD
18" Rims, big brake kit, Coil overs and freshly painted
Smashed Black VY SS Ute
The workhorse...
Twin turbo 5.7L LS1
Boyd Coddington 19" Turbine Wheels
AP Racing 4 Piston Brakes
Tein Coil over Suspension
HKS EVC 6 Boost Controller
PLX Devices DM-200 OBDII
Custom Front Mount Intercooler
