Go Back   Automotive Forums Car Chat > Mitsubishi > Galant
Old 04-09-2010, 09:26 PM
scubamartin scubamartin is offline
High Beams not much different from main beams
I have a 2000 Galant which my brother in law rewired the headlights on because they were corroded.
Since then the High Beams are almost the same as the main beams??? You can see a difference, but it is miniscule.
Any ideas to what could have gone wrong?
And also, can I put in a higher watt bulb?
Would greatly appreciate any help
Old 04-11-2010, 09:25 AM
RahX RahX is offline
Re: High Beams not much different from main beams
Make sure the bulbs are installed correctly, I see that quite a bit. And make sure that he didnt wire both high and low beams to be on at the same time.
Old 04-14-2019, 05:52 AM
stream stream is offline
yeah something is wrong because on ours the difference is way a lot - wish my low beams were a bit brighter
