Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 04-09-2010, 06:29 PM
AmysTrooper's Avatar
AmysTrooper AmysTrooper is offline
Odd whistling or squealing noise at idle and engine lite on.
The 98 3.5 has a new odd thing going on, a strange whistling noise which is loud at idle and the idle is rough too so the engine lite came on. This noise is constant, appears to be from the front on the motor, the motor revs fine and sounds good other than a rough idle. Im not sure on this one, looked around didnt see anything apart or pulled apart, all hoses seam attached. You guys have any ideas???
Old 04-14-2010, 12:44 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: Odd whistling or squealing noise at idle and engine lite on.
Could be a vacuum leak.
Have you have the CEL codes read?
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 04-14-2010, 01:36 PM
Figured it out last night, a manifold gasket. This is a common problem I guess and I dont know if it has been done before but looks as a possibility. I changed upper and lower gaskets and its running better than it has for the last few months, so maybe this has been an ongoing problem which just surfaced by the whistle noise. Carb cleaner helped me find the area, by spraying it lightly the idle changed when I got to the area of the leak. Thanks for your comment and suggestion.
