Old 05-01-2003, 12:23 PM
T-Mo's Avatar
T-Mo T-Mo is offline
Send a message via AIM to T-Mo Send a message via MSN to T-Mo
Getting off door panels
OK, I finally gutted the interior of the car. My problem id getting the door panels off. I got all the screws I think???
I got the one behind the latch, the ones on the sides, and the ones on the bottom. I pulled on it and it isn't coming off.
I think I have to take the window handle off, but how do I do that??? Also if there is anything else I need to do.
I dont have a book.
Old 05-01-2003, 01:14 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
To remove the handles, there's a clip that you have to remove...
If you pry the crank away from the door a bit and look at the shaft that it's mounted to, you'll see a small brass wire clip that holds the handle on. Just push that clip off of the shaft and the handle will come off.
