Old 04-09-2010, 03:00 PM
Black_Blade Black_Blade is offline
Most modern vehicles have a clear coat applied?
I have some rust repairs I need to see to on my van, the one bad one is in the lower left corner of the passenger side sliding door opening, which is going to be sooo much fun gaining access to. This particular spot has slipped notice and eaten through the metal and I can poke my finger thru into the wheel well. All other spots I've noted are small blemishes that are in easy to access areas.
My Canadian Tire store is trying to order me in some color matched paint, but they said it was a non stock item in ominous tone, so not sure if that means they won't be able to get it or not...
My question is, does the Winstar have a clear coat on its finish? I asume that most modern vehicles these days all have clear coats. It is the factory paint job, so it must be right? This body repair book I have been checking out, in preparation for my stint as a body repair guy, mentions the application of clear coats in the final steps...
Old 04-09-2010, 05:30 PM
northern piper's Avatar
northern piper northern piper is offline
Re: Most modern vehicles have a clear coat applied?
yep it's a base coat, clear coat system for sure. If you want to learn a ton of info about body shop repairs, go to www.autobodystore.com. I use that site a lot and have successfully done lots of body work and painting on my w/s among other vehicles. Go to a local auto parts place and have them mix up the paint. Don't fiddle around with CTC. Take it from another Ontario Canadian, CTC is good for some stuff, not autobody supplies.
P
2000 windstar 3.8
2010 honda pilot touring
Muskoka Canada
Old 04-09-2010, 06:34 PM
wiswind wiswind is offline
Feel over the lower body areas to see if there is also a plastic coating IN ADDITION to the clearcoat.
If it is present......you will be able to feel a line where this coating ends.
It will end no more than about 6"to12" from the bottom of the body.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 04-09-2010, 08:21 PM
P
Thanks for the link, Piper, will do some reading on there for sure. Guess a body shop would mix up your paint cheaper than going to Ford...
Old 04-09-2010, 08:26 PM
Didn't notice any extra layer...so I guess that's a good thing...
Old 04-10-2010, 10:42 AM
I will guess the the rust you got developed from the inside.
I got some at the same location you mention.
I also had some on the rocker panels (below the doors), which also developed from the inside.
The rest of the vehicle was still rust free.
The vehicle had been rust proofed and undercoated when new.....and when I got it.....I went over the underbody several times touching it up.
No help for the rocker panels because there was some foam type filler in there.....held the water and salt.
Rust came through on my '96 3 years ago in those locations.
1996 3.8L Windstar
Old 04-10-2010, 12:21 PM
I noticed that filler foam stuff too, it must start right around where my hole started. That's great then, have more to look forward to all along the rockers...wonder who was the genius to think up that foam...
Old 06-16-2010, 06:59 AM
AngelinaJolia AngelinaJolia is offline
Post Most modern vehicles have a clear coat applied?
If you want to learn a ton of info about body shop repairs.
Old 04-07-2011, 10:20 PM
Groundupautosports's Avatar
Groundupautosports Groundupautosports is offline
Most likely it is base coat/clear. But regardless of what kind of paint you use..one stage or bc/cc..you will need to have the rust cut out and replaced with new metal or it will come back out down the road. Have any questions or need any advice...contact me..be glad to help.
www.groundupautosports.com
Old 04-09-2011, 01:41 PM
big white bufflo big white bufflo is offline
I have done some auto body repair in the past and am going to do my wifes winne lower rocker this summer with older paint it fades you can hide the newer paint and blend it by useing the chipguard to your advanage to hide the lines its not as shinne but also has a texture to it and may prevent future rust i plan on useing this on wifes winne good luck on the repair
