Old 04-09-2010, 01:30 PM
capone530's Avatar
capone530 capone530 is offline
weird....2001 silverado
drive to the bank..truck was fine..go to leave the bank..start the truck up and it shuts off right away..start again..shuts off right away..i drive it home like 5 blocks pushing on the gas when i come to a stop..only way to keep it running..otherwise if i come to a complete stop it would shut off the second i push on the gas..if i put it in park it would run but the rpms would be wayyyy low...so i get it home and let it set for about 30 min..go back out and it fires up like normal and i take it around the block and runs like normal..truck has half a tank of midgrade in it so i know i'm not low on gas..wtf is going on guys?
2000 chevy silverado, ext cab all mouldings shaved..lowered..5.3 v-8 with k&n intake and flowmasters sitting on 20's
Old 04-09-2010, 02:24 PM
j cAT j cAT is offline
Re: weird....2001 silverado
no check engine Lights you must check fuel pressure ...use the proceedure here at this forum for your vehicle...need pressure guage..
if pump is defective get delphi pump...other pumps fail quickly..
Old 04-09-2010, 03:42 PM
capone530's Avatar
yea prev owner liked to drive the truck on under 1/4 tank alot..prev owner only drove the truck around town mostly..had the truck for 3 yrs and barely put 5k on it..in the last month i have put over 1000 on it easy..so i'm guessing this pump is on its way out..been drivin around town all day with no problems though so i dunno what happen this morning..i also tried to replace the drl's and they don't even work with new bulbs
Old 04-09-2010, 04:40 PM
guessing is not required . use the fuel pressure testing proceedure ..
DRL lamp has a fuse . check the fuses /....get the new lamps that are long life ////I think 4157 LL ..auto zone has them ...
Old 04-09-2010, 10:10 PM
capone530's Avatar
yea i dunno whats going on..went to go to the store tonight and it tried the same stuff so i reved it a few times and drove a few blocks doing the whole foot on brake and gas at the same time then the truck started running fine..i dunno wtf is going on..this is happening out of nowwhere..and as far as my drls i checked the fuses they looked all good the only thing it could be is the main relay for them but when i changed out the bulbs the plastic where the bulb plugs in was browned and burned looking so i dunno..
Old 04-10-2010, 08:30 AM
the bulb lamp socket does turn brown this is normal ...
you must get a volt ohm meter to check / troubleshoot these problems..
with your fuel, once again you must use the testing proceedure with a pressure guage to troubleshoot your engine running issues ..
Old 04-10-2010, 04:58 PM
Ryan Hermann Ryan Hermann is offline
Try some fuel injector cleaner. Maybe fuel system is a little dirty.
Old 04-10-2010, 07:26 PM
capone530's Avatar
i wonder if it is related to my smog check valve problem..the truck did it today again..drove to the store with no issues..get back in it and start it it shuts off then drove a few blocks with foot on gas and brake at stops then it clears up...almost like on an older car when u don't let it warm up or somthing.. i dunno wtf is going on..was thinking about dirty gas too since i just got alot of gas but it seems to do it after taking a short trip and shuting the truck off...
Old 04-10-2010, 09:35 PM
capone530's Avatar
i feel stupid but by chance would a loose batt connection cause these problems?? stalling..not wanting to stay running...
i was turning my truck around in the street and it went totally dead..no click no nothing so i tighten up the batt wires and truck fired right up with no problem..could this of been the problem the whole time was a loose batt connection..about 4 days ago my amp wire got ripped out from the batt bolt that left a gap..right now when i tighten it it went all the way tight..no gap..so is this my problem maybe?
Old 04-13-2010, 06:42 AM
deadmeat deadmeat is offline
This could do it too. I actually had similar happen shortly after I got my truck. Took it to the dealer and they replaced the battery (under warranty) after testing determined it was not holding a proper charge. No problems since.
Old 04-25-2010, 11:20 AM
capone530's Avatar
Cool Re: weird....2001 silverado
yea i'm dumb it was the battery..i checked it and it was not tighten very good so i cleaned the terminal and tighten it and its been fine for a few weeks now..
Old 04-25-2010, 08:03 PM
you fixed the problem and it was a free fix not bad ...
thanks for the post on correcting this ..
Old 05-20-2010, 10:25 AM
edj0527 edj0527 is offline
Send a message via AIM to edj0527
Had a the same problem and I tightened the battery terminal as well. Today the Fuel Pump finally gave out. Wife was doing about 55 on US1 here in florida when the pump finally quit working. Truck came to a stop and it is in the shop now getting the Pump replaced. I got 8 months out of it after the Battery tightening. If its still running fine then great. If you start noticing Hesitation and rough running in the near future It will be time to replace it.
