Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 04-09-2010, 01:23 PM
baby141 baby141 is offline
Rear wiper blade - 2002 Venture
The rear wiper blade is not working. It goes to the half way mark and gets stuck. I hear the motor trying but it will work only if I assist it. Does this sound like a motor problem or is it just the part that is not working.
Old 04-09-2010, 09:14 PM
roadrunner2 roadrunner2 is offline
Re: Rear wiper blade - 2002 Venture
When the wiper motor reverses and rotates the spindle to the 'park' position, will the wiper move back with it?
When it goes to center and you help it, will the motor reverse and return the wiper back without your help?
It's one of two things, either the wiper motor spindle is partially stripped or the motor is faulty.
The problem with doing nothing is not knowing when you're finished.
Old 04-11-2010, 03:53 PM
markqc markqc is offline
I had a similar problem. There was a stripped tooth on the plastice gear which moves the wiper. Unfortuneately, you can't buy the gear only. You can buy a "wiper module" either remanufactured or new, or check a junk yard for a used one.
Mark
Old 04-11-2010, 11:15 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
What is the difference between the both suggestion?
Yes for the two, you should replace the wiper motor.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 04-14-2010, 10:26 AM
dkr8611 dkr8611 is offline
I had a similar problem with mine. It would only go one direction and then sort of stop. All I had to do was open the cover at the base of the wiper arm and tighten the nut.
I had purchased a new motor and everything, but that was all I needed and I took the part back unused.
