Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 04-09-2010, 01:17 AM
jeremy06 jeremy06 is offline
Send a message via Yahoo to jeremy06
1998 venture sensors?
where are the camshaft position sensor and crankshaft position sensor located? try to be describive. Thank you
Old 04-09-2010, 10:36 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: 1998 venture sensors?
The cam sensor is right under the P/S pump. The connector is to the right of the oil fill clipped to the bracket that mounts on the intake plenum bolt.
Old 04-09-2010, 10:55 AM
lesterl's Avatar
lesterl lesterl is offline
IIRC the Crank sensor is behind the Harmonic Balancer. Connector comes out below the water pump/ above compressor.
1997 Chevrolet Venture SFI 3.4l Auto 249k
2006 Chevrolet Malibu Maxx SFI 3.5l Auto 81k
http://www.s10forum.com/forum/attach...nsor-chart.gif
Old 04-09-2010, 02:34 PM
Airjer_'s Avatar
I couldn't remember if there where two crank sensors or not. Isn't there a low res one in the block on the firewall side as well? I think that's the one the the connector at the ignition module with the purple yellow wires go to. The [one behind the pulley is the high res and goes to the PCM. Again I'm going on foggy memory today. I should now that but it just isn't clicking!
Old 04-09-2010, 02:46 PM
lesterl's Avatar
The Crank sensor is a 7X, the Cam is a 24X or sumtin like that IIRC. I know there is a sensor between the narrow part of the transaxle and the side of the block, IDK what it is IIRC it is 2 wire and doubt it would be a position sensor as they are usually 3 wire.
Old 04-09-2010, 02:55 PM
Airjer_'s Avatar
I thought the one behind the crank pulley was the 24x crank sensor. The 2 wire in the block that goes to the ignition module is the 7x crank sensor.
Old 04-09-2010, 03:13 PM
lesterl's Avatar
Crank sensor is the 2 wire unit, the other 2 according to the wiring diagram are the cam sensors, IDK which is the 24x, I would suspect the one under the PS pump. - All info from www.autozone.com....... :-)
