Old 04-08-2010, 04:36 PM
quicdraw10 quicdraw10 is offline
Question 93 grand prix radiator fans not coming on
fans not coming on,replaced the sensor below the thermostat i think its called temp control,checked the fans they work, checked the relay its good, checked the wireing it looked good.what else could it be any help!
Old 04-09-2010, 08:51 PM
TDWPgtp's Avatar
TDWPgtp TDWPgtp is offline
Re: 93 grand prix radeator fans not coming on
are u sure they need to? maybe its staying cool enough without them..
i know my temp gauge is wrong and for the longesst time no one could figure out why my fans werent goin on when it was over heating. turns out, it wasnt really over heating
Old 04-10-2010, 05:40 PM
Question Re: 93 grand prix radeator fans not coming on
yes it was over heating,it would shut the moter down when it got hot,the gauge was almost in the red. i changed the temp sensor back about 7 months ago fans still did not work, i drove it every since it would do fine unless you got stuck in traffic then it would overheat,now two days ago i tryed something i read on hear i unpluged the temp sensor below the thermostat start the car and the fans come on and the check engine light. now the next ? bad sensor? i bought the old one new but it never worked,also will this harm the moter with the fans running all the time? ill replace the sensor soon and try again its only 11 dollars,also would this make the torque converter lockout get hot and start acting up, cause when you drive it and it gets hot the car shuts down in drive,but in park it runs just fine,so i unpluged the torque converter lockout from tranny,now it runs fine no shutdowns but it seem ive lost the overdrive gear in the tranny??? i also bleed the air out of the thermostat housing.thanks any help would be great!!!!!
Old 04-10-2010, 06:10 PM
Originally Posted by darkangel8 View Post
Are you sure that the wiring is good? Check gain or maybe there's a problem with the fun itseft try to inspect other stuff near the fun.
done it all looks good
Old 04-11-2010, 11:10 PM
TDWPgtp's Avatar
Re: 93 grand prix radiator fans not coming on
hmm i have no idea ha. i wish u luck figuring it out tho
Old 07-09-2010, 01:42 AM
Jfuzzy1 Jfuzzy1 is offline
I have the same trouble. Fans will only operate when the ECT disconnected. Any fix for this?
Old 07-23-2010, 08:30 PM
84hurst 84hurst is offline
Not sure if you solved your problem yet or not but I had the same issue on a 94 cutlass 3.1. Relays were fine, fuses were fine, fans worked fine when 12v were put directly to them and also when the coolant temp sensor was unplugged. Never did figure out what exactly was wrong but I just wired the fans into an item that only gets power when the ignition is on. Ie fuel pump or other similar. Now the fans always come on when the key is in the on position. BTW when you say you lost your overdrive after unplugging the torque converter that is normal operation. You're torque converter will no longer "lock" and drop the rpms a couple hundred.
