Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 04-08-2010, 10:37 AM
basshole basshole is offline
Question warm weather stalls??
what would cause engine to stall when weather warms up? 96 ford E--150.....has nothing to do with engine temp, which seems ok, but when outside temp warms up it runs like crap. i'm leaning towards a sensor or filter? if anyone has had this problem i would love to know how you solved it....THANKS
Old 04-08-2010, 10:51 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: warm weather stalls??
Warmer air can hold more moisture (humidity). It may be that this moisture is affecting frayed or corroded electrical wires or even the spark plug wires.
I'd start with checking the spark plug wires. Run the engine in the dark with the hood up and watch for any sparks/light. If you see any, you need to replace the wires.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
