Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 04-07-2010, 09:24 PM
turkey28 turkey28 is offline
Question which alternator?
How do I tell if my 2002 3/4 ton Suburban has the 105 amp or 130 amp alternator?
I want to buy a belt and have to know.
Old 04-08-2010, 02:50 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: which alternator?
If it is the original alternator, you could copy the part number and crosscheck it online or call the local dealer. They can also look up your truck from the VIN and see what was installed at the factory. Auto parts stores can usually crosscheck the numbers as well.
Alternatively (no pun intended), you can look for one of the following RPO codes for a 130 Amp alternator on the sticker inside your glovebox: 8A7 or KG8.
But frankly, I'd guess the belt would be the same part either way...good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 04-08-2010, 10:38 PM
Elbert Elbert is offline
generally belts are not the same. Different size pulley most of the time.
Elbert Clarke
Old 04-08-2010, 11:24 PM
Scrapper Scrapper is offline
AF Premium User
Question Re: which alternator?
if it came out fully loaded it will be the 130 amp also.
Old 04-09-2010, 06:24 AM
They do have different part numbers listed for the belts.
I figure it is probably 130 amp, it is an LT and has every option I can think of on it. I'll check the codes in the glove box today.
Old 04-10-2010, 01:20 PM
Cusser's Avatar
Cusser Cusser is offline
I think the easiest way is to read and write down the BELT part number, and let the parts store cross-reference it. Or just take the serpentine belt off (draw a routing diagram if your underhood doesn't have the sticker) and take it in to the parts store, mine (1994) just takes a 5/8 inch socket on a 1/2 inch breaker bar to do that.
Keep that old serpentine belt as an emergency spare.
Old 06-21-2010, 08:52 AM
keraf keraf is offline
What is a good expectation for life of an alternator? I've got a 93 Sub C1500 with a 105 Amp Delco Reman with 76k miles on it. Bearings are fine so I suspect the brush life will dictate the life. Any ideas on this? I don't want to be surprised on the road and will change it out as a PM project if I'm within the window of life expectancy range. Thanks.
Old 06-21-2010, 09:56 PM
j cAT j cAT is offline
with normal highway / city idling time the brushes last about 180,ooomi....this would be with your older more reliable cs alternator..
the newer ad alternators when built in the late 1990's had issues with the voltage regulator getting damaged from the corrosion eating at the runs ..
my ad 2000 alternator 105amp failed with this issue ...bushes at 125,ooo mi were about 60% worn if that ...
I don't recommend or use remanufactured alternators ...too many issues / failures ...
