Old 04-07-2010, 09:25 PM
guitarfish's Avatar
guitarfish guitarfish is offline
Diagnosing noise - wheel bearing?
The front of my '08 Prix is making a noise, most noticable when turning the wheel to the right at moderate speeds. I drive 100 miles on the highway every day, and I don't notice it on the highway. I've had wheel bearings go south before. where I hear them all the time, and worse the faster I go. This isn't like that, not yet anyway.
It seems to be on the front right. Waw waw waw kind of sound. I jacked up the wheel, there's no play in the bearing, and when I turn the wheel by hand, I don't hear anything unusual, with the wheel straight, and turned.
My question is, what other things could it be besides a wheel bearing? I'm confident it's not the tire, as I've swapped them around, no change. It's also not loose lug nuts.
I've heard bad CV joints before, they're usually click-click, but it's not like that.
Just looking for ideas, if this sounds like a wheel bearing.
Thanks!
Current Grand Prix
2008 GP - 174,000
Former Grand Prix's
1994 GP SE - 231,000
1997 GP GT - 134,000
1998 GP GT - 225,000
2002 GP GT - 222,000
Old 04-08-2010, 07:28 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Diagnosing noise - wheel bearing?
Does the sound change based on speed. A bad wheel bearing normally changes pitch in sound as speed increases. At what speed does the noise start?
Timeslip 08/12/06
AF Community Guidelines
Old 04-08-2010, 10:57 AM
guitarfish's Avatar
The problem is I only hear it when turning, and I can't go very fast or far turning. When I pull into a local store there's a long tight curve and I hear it real well at 15mph. I hear it at 40-50 mph on turns. It's not a high pitch or whine, more of a low grind noise. Not noticably different based on speed.
Current Grand Prix
2008 GP - 174,000
Former Grand Prix's
Old 04-08-2010, 01:31 PM
rkvons's Avatar
rkvons rkvons is offline
Check the inside surface of your rotors. If your caliper pins were not greased properly in the past, you will get excessive force on your inside disk pad/rotor surface and it will really messed it up. Going fast, this surface rubs slightly on your pads and will sing, especially while turning. I am currently dealing with the same issue. I just learned that there is a special grease for the caliper pins. If I depress the brake pedal ever-so-lightly, as I approach a stop, I can hear the irregularities of the rotor surface rubbing on the disk brakes. In a couple of weeks, I plan on redoing my front brakes to see if the noise goes away. I just did my right front hub assembly and was shocked when I saw the inside surface of my brake rotor.
Old 04-08-2010, 08:40 PM
JonJon68 JonJon68 is offline
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
I just bought some Permatex Ultra Disc Brake Caliper Lube. It's a synthetic grease/lubricant especially for caliper pins, slides, bushings, pistons and rubber sleeves and seals. I don't think using just any grease will hold up under the high heat and pressure.
1997 GPGT 3.8 Dark Teal Metallic. 222000
4 door sedan
No Mods
Old 04-08-2010, 09:00 PM
guitarfish's Avatar
I installed new (resurfaced) rotors and new premium ceramic pads about 2 weeks ago. I cleaned & greased the pins with a red Valvoline grease which says it's for GM Ford Chrysler, extreme high heat, for brakes, bearings, etc. I've used it for several years on my cars without problems.
In any event, the noise I'm hear preceeded the brake job. I guess I'll pull the wheel and take another look on the weekend. It may end up that it has to get worse before I figure it out. Perplexing.
Current Grand Prix
2008 GP - 174,000
Former Grand Prix's
Old 10-08-2010, 10:42 AM
jvandermolen jvandermolen is offline
I have very similar issues with my 2004 Grand Prix. I've taken apart both front wheels and can't find any free play in the bearings. My brakes are fairly new so I know it isn't that. Plus the noise doesn't change when I apply my brakes. I can only hear it at low speeds, turning left, turning right, and sometimes even going straight. My right half shaft was just replaced due to a cracked boot - I'm wondering if they screwed something up in the process.
I've done a lot of research on this and bought a Haynes manual. At this point I'm going to hammer down and drive it and let the issue progress to a point that I can diagnose!
If you find anything please let me know.
Funny side story - I brought it in to a local shop against my will and they said that the sound was coming from the tire bead rubbing on the rim...don't think so.
Old 10-08-2010, 10:46 AM
guitarfish's Avatar
I started this thread 6 months ago, and I'm still driving the same noisy car. I'll be pulling the wheels and switching over to my winter tires soon, it'll be interesting if there's any change. Cars...
Current Grand Prix
2008 GP - 174,000
Former Grand Prix's
Old 10-08-2010, 05:50 PM
3100 3100 is offline
Banned
don't check the front right, check the front left, because you say it makes noise when turning right, so imagine what happens to you when you turn fast right? your body goes to the left, now the weight of the vehicle shifts also left so there is no pressure on front right wheel only on the front left. So check front left bearing, front left tire, front left fender inside plastic for signs of tire scraping.
Old 10-09-2010, 10:59 AM
BNaylor's Avatar
guitarfish,
What is your current mileage? Hopefully not above 100K miles. Obviously not 5 years since you have a '08 base model. FYI - Your GM 5 yr/100k mile powertrain warranty covers front and rear hubs/bearings and axle shaft/cv joints. Also, I verified through a local Pontiac dealer service department it would be covered.
Timeslip 08/12/06
