I have a 95 Taurus GL. The problem is after driving it a while it will just die. It seems to lose all power at first and then will not go. It does not over heat, no check engine lights, nothing. After I let it sit for a while, it will start right up. I have changed the plugs and wires and also the igntition control module. Seemed to do the trick for a while, but then the same thing happened again. Could it be the the coil overheating or a fuel problem. Have not checked either one yet. I have also had the catalytic converter checked.
Re: 95 Taurus GL
When it dies check to see if you have spark, if so then check for fuel pressure.
