Old 04-07-2010, 09:28 AM
Bob B Bob B is offline
automatic tranny question
Hi,
My 97 K1500 developed a strange thing yesterday.
When you shift into drive from neutral it seems normal with one clunk.
But from reverse to drive, it has a double clunk like taking up some play.
Same from drive to reverse.
Any thoughts?
Thanks for any help,
Bob B
Old 04-07-2010, 10:19 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: automatic tranny question
First check the driveshaft u-joints by chocking the front wheels, jacking up the rear and trying to rotate the shaft. There should be zero play at the joints.
Then check the tranny fluid for proper level and quality. If it is old, very low, looks opaque brown, or smells burned it needs to be changed. Better would be to change it and the filter, run 50-100 miles, then change the fluid again (leave the filter) to get out more of the old, bad stuff. DO NOT HAVE A POWER FLUSH DONE. A good fluid change smooths out shifts considerably.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 04-08-2010, 04:15 PM
transman618 transman618 is offline
Other than the clunking during engagement, how is the transmission performing?? Does it shift out ok?? Does reverse work??
transman
GM MASTER TECHNICIAN
SR. TRANSMISSION BUILDER
Old 04-09-2010, 09:24 AM
transman
Hi,
Yes it feels normal otherwise.
Bob B
