Go Back   Automotive Forums Car Chat > Honda > Odyssey
Old 04-07-2010, 09:48 AM
stephennpennie stephennpennie is offline
05 odyessy with code p0966
I am getting a trouble code on my honda it P0966. The readout says it is a pressure control solenoid B control circuit voltage Low. Does anyone now where orthis solenoid is. Also the engine light is on and D light blinks, and the car seems to be stuck in third gear.
Old 04-07-2010, 07:43 PM
cherryelky305 cherryelky305 is offline
Send a message via AIM to cherryelky305
Re: 05 odyessy with code p0966
its the clutch pressure control solenoids, they are located on the top of the transmission. you have to take the air box and several hoses and pipes off to get to them.
there should be two valves that look the same right next to each other, while your there i would just go ahead and replace them both.
no idea how much those valves cost but most shopes would charge an hours labor to install.
1980 El camino
2002 LS1 swap
