Go Back   Automotive Forums Car Chat > Oldsmobile > General Discussion
Old 04-06-2010, 10:38 PM
bbfalls bbfalls is offline
Emissions and egr valve
I should know the answer to this but I don't; does anyone out there know where the EGR valve is located on a 92 Toronado trofeo 3.8L. auto.
I looked and looked and did not see it. I have learned it does not have the typical look of an EGR valve that I am used to but, either way I cannot seem to locate it.
I wanted to test it, (if possible) as my car did not pass my state emissions test - The NO reading was WAAAAAAAAAAAy too high. HC and C0 were fine.
Thanks in advance.
bb
Old 04-07-2010, 12:03 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Emissions and egr valve
If it had the electric EGR has three solenoids with a connector in the center. I think its near the distributor on the drivers side of the engine. It's been a long time since I have seen one of those let alone work on one.
Old 04-07-2010, 10:54 PM
Thanks I will look again; however my toronado is a distributorless ignition.
Old 04-08-2010, 02:11 PM
maxwedge maxwedge is offline
A990 racer
Here it is. http://www.napaonline.com/Search/Det...+50052+2052027, at Napa.
Old 04-12-2010, 05:58 AM
Maxwedge - Thanks for the link/pic...that is a really good image - however I do not see that anywhere in the engine compartment. I had a friend look under the hood as well and he could not find it either!
Does anyone out there know if maybe my car/model just does not have one?
Car is not showing any codes with the onboard diagnostics.
All lines and ports seem to be in use and there is nothing erroneously plugged.
Old 04-12-2010, 07:54 AM
A990 racer
92 may not set a egr codes, I don't remember whether the l engine had an egr, try googling 92 olds egr see what you find. Usually nox is a result of an inop or clogged egr or very hot running engine, or a bad cat.
Old 04-12-2010, 03:30 PM
cat is after market - more time on it than mileage...probably only 25k miles on it.
...Usually nox is a result of an inop or clogged egr...That's why I was trying to find it/inspect it/fix it/replace it...
I will be changing the thermostat, o2 sens, air filt, and pcv valve before I go for e-check again...also ran a 'guarantee to pass' emissions cleaner through the tank.
I am beginning to think this card does not have one...But there has to be one on a 92 right! It has to have either a tube or hose(?) going from either the intake or an exhaust manifold right! AAAARrrrrrgh!
Old 04-12-2010, 03:55 PM
I just spoke to a great parts counter at a dealership and they took my vin and called GM and according to them, gm states this car does not have a egr. I don't know why or if i believe it, (since its a 92??) so I am still going to look at the different areas under the hood again...
Old 04-15-2010, 10:39 PM
Hmanor3 Hmanor3 is offline
Some '92 3.8L did not have a EGR valve. GM decided it was not required to meet that years emissions standards.
Old 04-23-2010, 07:27 PM
Well 3rd time was a charm. The additive to the tank did not work (failure 2); I'm not surprised, but it was the cheapest possible fix to try first. So of course after that I had the cat converter replaced; and then it passed. I guess they don't make aftermarket converters like they used to, (or at least not even close to a factory converter).
Everyone, Thanks for all of the help!
Old 07-20-2010, 10:01 AM
Greg Breitung Greg Breitung is offline
I have a 1990 Olds 88, it runs poor under load- I have cleaned the intake sensors- Does this car have a EGR valve- if si where is it?
Old 07-20-2010, 10:36 AM
Airjer_'s Avatar
The EGR is not your problem! You may be better off starting a new thread with a better description of your symptom.
