towing '92 front wheel drive camry
will it damage the drive train to tow my '92 camry with a chain behind a pick up even if it's in neutral and for a distance of roughly 10 miles?
Thank you, Jon |
Re: towing '92 front wheel drive camry
For only 10 miles, it shouldn't damage your drivetrain much. But as for your ability to stop a vehicle towed by a chain if the truck in front suddently stops, that would be dependent upon the skills of the driver in the 92 Camry!
Not but leave the key in accessory position to unlock the steering column.
2003 Chevrolet Impala LS 3.8L OHV 2002 Ford Taurus SE 3.0L OHV (sold) 1998 Ford Windstar LX 3.8L OHV (sold) 2002 Chevrolet Malibu LS 3.1L OHV (sold) 2004 Hyundai Accent GS 1.6L DOHC manual (sold) 1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold) 2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold) A Windstar without having the check engine light is not a real Windstar.
I wouldn't do it. You may damage your transmission. The only way your transmission gets oil to the bearings is by the engine powering the transmission and turning the transmission oil pump. You will turn the output shaft and bearings without oil supply. You may not damage it, but I wouldn't take the chance. Lift the front wheels.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html "What we've got here is a failure to communicate" Last edited by Brian R.; 04-06-2010 at 04:37 PM. |
I agree with that. When front wheels turn, the output shaft turns with it. Even if it's in neutral and if the clutch is depressed.
thank you all for your imput. i ended up having it hauled home on a flatbed, because with my luck something expensive would happen it i tried to get out cheap.
thank you, Jon |
