Old 04-30-2003, 01:20 PM
DArkforces9 DArkforces9 is offline
Send a message via ICQ to DArkforces9
Lowering Springs
Will lowering springs from a 98 Civic fit on a 91 hatch?
Old 05-01-2003, 06:31 PM
Come on nobody knows?
Old 05-01-2003, 06:37 PM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
they should....the coilovers i have say they fit 88-00 civics just try and find out but i bet they do
Keep it real, and share the knowledge.....
Say NO to Primer!!
Old 05-02-2003, 12:39 AM
AlwaysMovin AlwaysMovin is offline
It is always best to get springs made specificto the vehicle year. Otherwise you runthe risk of getting an improper spring rate. Which can give you either a super rough ride. Or a ride so soft you scrape the ground and get bad handling.
If you are ever in the southwest desert and you see a dust storm coming your way, when I see you I'll wave hello.
My Home Page: Under Heavy Construction
Old 05-02-2003, 12:45 AM
VelocityCivic91's Avatar
VelocityCivic91 VelocityCivic91 is offline
Send a message via AIM to VelocityCivic91
Otherwise you run the risk of getting an improper spring rate.
Hes right... 88-00 are the same springs, just different spring rates... in this case, the spring rate will be pretty stiff because 98 Civics are A LOT heavier then our 4th gens.
WARNING: Surgeon General says it's O.K. to smoke V-8's.
*** Looking for a B&M fuel pressure regulator and guadge***
