Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 04-05-2010, 09:07 PM
venturenot venturenot is offline
MAF Sensor values on Scanner
The manufacturer advises that on a fully warmed engine the MAF Grams per second values should be between 4 and 7. My readings are around 3.75. Does this mean that my MAF is on its last leg? .....Just curious.
I cleaned the sensor to see if I could get the values to change, but they did not.
"The scan tool reads the MAF value and displays it in grams per second (gm/s). At idle, it should read between 4gm/s - 7gm/s on a fully warmed up engine. Values should change rather quickly on acceleration, but values should remain fairly stable at any given RPM. A failure in the MAF sensor or circuit should set DTC P0101, DTC P0102, or DTC P0103."
Old 04-07-2010, 11:08 AM
dewaynep dewaynep is offline
Re: MAF Sensor values on Scanner
I wouldn't say it is on its last legs. From the text you provided yours is a little low, but that could be from a dirty air filter, low idle, loss of vacuum, low compression, etc... As long as it is steady I wouldn't worry about it, but I'm not you. What's the long term fuel trim look like? If it's negative then you may have a point, but if it's positive or close to 0 then I wouldn't worry about it, but again, I'm not you.
Old 04-07-2010, 11:58 AM
The fuel trim bounces from about -11 to -25 but it does not throw a code. Engine occasionaly stumbles upon acceleration and whenever I try to sustain a speed of 55mph it stumbles like crazy.
Old 04-07-2010, 01:14 PM
You may be right then, perhaps the MAF is getting weak. You should be able to disconnect the MAF sensor and the engine will still run based on the map sensor readings. Throttle response will be non-existant but you should be able to get up to speed as a check of the MAF.
Old 04-07-2010, 07:08 PM
Disconnected the MAF and it ran exactly the same as with it connected. The only difference was the long term fuel triim, it was not quite so bad. The readings bounced back and forth from -12.
Car really stumbles when I try to maintain 55 mph speed. No codes have been thrown ( except when I disconnected the MAF)
Old 04-07-2010, 10:27 PM
lesterl's Avatar
lesterl lesterl is offline
Had a very similar issue, cant remember what my MAF values were, but I told my uncle (GM mech) and he said Plug wires, I didnt believe him, so decided to do it to prove him wrong, all I can say is damnit, should have tried his idea earlier, now smooth as silk, a set of Bosch wires from autozone for $32 cured my issue (no codes either.)
1997 Chevrolet Venture SFI 3.4l Auto 249k
2006 Chevrolet Malibu Maxx SFI 3.5l Auto 81k
http://www.s10forum.com/forum/attach...nsor-chart.gif
Old 04-08-2010, 08:52 PM
Could be the wires, although my wires are fairly new AC Delco wires with about 50,000 mostly highway miles on them.
Funny thing today.. I took the van out on the highway and absolutely no problems. No hesitation or stumbling even the LT fuel trim was reading about -8. The only difference between today and the past week is that the air temperature dropped this afternoon into the 50's. It has been an abnormally warm April and earlier this week when I was having this problem the temps were in the 80's. I wonder if this is just coincidence or if the warm temps are helping to cause the problem?
Old 04-09-2010, 06:47 AM
Well, that's some new info. Have you looked at the IAT and ECT values? They should both be about the same before starting the engine. Then the IAT should go lower and the ECT should go higher. Sounds like maybe you have a bad temperature sensor causing a rich condition.
Old 04-09-2010, 10:02 AM
lesterl's Avatar
The IAT sensor wont change alot, the CTS however will change in a pattern of ohms like in this link -> http://www.s10forum.com/forum/attach...nsor-chart.gif
Old 04-09-2010, 10:33 AM
At startup the IAT numbers are the same as outside temp. However, after the car is warmed up the IAT goes up to 30 to 40 warmer than outside temp. Is this normal? The coolant temp seem to be pretty normal.
Old 04-09-2010, 10:55 AM
lesterl's Avatar
Does this warmup cycle involve driving the van? If you just sit and idle it could very well warm up, altho I think a 30-40* warmup is kinda excessive for the IAT. I will check mine later, but I suspect maybe you have a sensor issue or something like sitting still and you are getting heat soak from the exhaust that passes under the intake tubing where the sensor goes in the top.
Old 04-09-2010, 11:00 AM
The warm up involves driving the van. The other day it was about 80 degrees out and my IAT was reading 120 degrees while I was driving. This morning outside temp was 44 and after 20 minutes of driving my IAT was at 70 degrees.
I think I will just go buy a new sensor, they are only about $20.00. After disconnecting the electrical sensor do you just pry out the old sensor with flat head screwdriver?
Old 04-09-2010, 12:08 PM
lesterl's Avatar
We are talking about the IAT in the rubber boot right? Just pry it out, can pull out by hand, be careful if you are prying on it, might twist it Clockwise/ CCW to loosen it before tugging on it. Keep in mind you sensor may be good, it may just be getting excessive heat. The PCM does sit in the air box, perhaps it is getting too hot? Perhaps the EGR is not fully closing and the exhaust mixture is getting in the intake? Have you done a mechanical check with a thermometer? Pull the sensor out and use one of the probe style thermometers, will have to put some packing around to eliminate a vacume leak. Keep the old sensor hooked up but sitting over to the side, run it to where you were having misreadings and see if it is bad on the thermometer.
Old 04-09-2010, 09:00 PM
I just went ahead and bought a IAT sensor at Advanced Auto for $14.00. No change, IAT values are still about 40 degrees warmer than outside temperature. I think that it is safe to assume that the original sensor was not faulty.
Old 04-09-2010, 09:15 PM
lesterl's Avatar
On my 97, or the 00+ motor the EGR is firewall drivers side of motor.
I checked mine, it was reading (in town traffic) ~ 20* warmer...... Good luck.
