Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-05-2010, 10:14 AM
socamust socamust is offline
2001 mustang gt will not start
My Mustang 2001 turns over but will not start, I had not used the car for two months, So when I tried I had to charge the battery, with the battery charged it will not start, It turns over, And it had half tank of gas, This was on Saturday, On Sunday when I tried to start it, Same thing turns over but no start, I observed the gas Guage indicator reading about one eight of gas which I know is not accurate, And the low fuel light is on, But I still put in two gallons of gas, I checked the trip breaker in the trunk and it is okay, I checked the 20 amp fuse and it is good, I only have thirty thousand miles on this car, it is GT, 4.6, hardly used.
How can I recitfy this problem?
Please help
Thanks
Soca.
Old 04-05-2010, 11:09 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: 2001 mustang gt will not start
Can you hear the fuel pump engage for a second or two when you turn the key to ON? If not, the pump might be shot. If you can hear it, check fuel pressure and check for water in the fuel.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 04-06-2010, 09:44 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Please help
Thanks
Soca.
I had a similar issue on mine after sitting in the garage over winter. There are two relays for fuel/ECU. One strictly for the fuel pump, so take note when you turn the key to the on position if you hear the fuel pump or not. If you hear don't hear the pump prime, then the fuel relay could be at fault. If you do hear the pump prime, then you could look at the ECU relay.
A motor takes 3 things to run; fuel, spark and air.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
