Old 04-05-2010, 08:48 AM
bopritchard bopritchard is offline
Unhappy 91 1500 will not Start!!!
My truck will not start. It's a 91 w/ a 4.3. Last drove it 2 weeks ago. It turns over good and is getting gas(you can smell it from the carburetor). The distributor cap and rotor looked a little worn so I replaced those. Still nothing. So I replaced the ignition coil. Still nothing. What are the next logical things to be checking?
I know there are probably a bunch of things it could be, but if someone can point me down a logical path of things to be checking I'd really appreciate it.
Thanks
Old 04-05-2010, 10:08 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 91 1500 will not Start!!!
Good start so far, though I would have tested the coil first before simply replacing it. Make sure you're getting a spark from the main coil lead
Next steps would be to check the EGR and IAC valves, and test the engine coolant temp (ECT) sensor mounted near the upper coolant neck.
After that I'd check for proper fuel pressure and spray pattern from the injectors. You should be able to faintly hear the fuel pump start up when you key-on the ignition...rolling the window down and being in a garage helps you hear it. Your gen diesn't have the fuel pressure test port so you'll have to find an adapter tee fitting to put a gauge on it.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 04-21-2010, 07:48 PM
smithjim94 smithjim94 is offline
Just a thought and I don't know if your year model has an ignition module within the distributor but I'd try that. Mine died on me a few months ago with the same symptoms. It would turn over perfectly and had fuel. No spark w/o the module though.....good luck.
