Old 04-04-2010, 11:50 PM
pingdaddy_1999 pingdaddy_1999 is offline
Question 97 Cavalier - Won't Start - Died while on interstate
I have a 1997 Cavalier with 166k miles. While driving on the interstate, it died and I coasted to the side, unable to restart the engine. After getting it home, I ran through the general steps of trouble shooting... You can hear the fuel pump, all spark plugs are firing, etc... I did get some trouble codes, P0342 (Camshaft Position Sensor A - Bank 1 Circuit Low Input) and P0113 (Intake Air Temp Circuit High Input). I replaced the fuel filter with no different results. I pulled each spark plug and cranked the engine to ensure all were producing spark, and they were, but noticed something. The two cylinders on the passenger side seemed "dry" (as in no presence of fuel) and the two on the drivers side seemed very "wet" and would produce a mist of fuel when the engine turned over. I was unable to check fuel pressure basically because I am not sure how to... Can anyone shed some light on what the problem may be or at least the procedure I will need to follow to check fuel pressure?
