Old 04-04-2010, 11:43 AM
svotta svotta is offline
No horn!!
I have a 1990 lumina and I brought it to get two new rims put on at my school and a kid pulled back where you push to use the horn and now it doesnt work. How do I fix it.
Old 04-04-2010, 12:15 PM
jdl jdl is offline
Re: No horn!!
I'd start by using voltage tester on the fuse and circuit, even if the fuse is good, if no voltage on the circuit, the circuit is dead.
Old 04-04-2010, 08:32 PM
Re: No horn!!
Thanks JDL. I tested the voltage and it was dead the fuse was blown. it shorted out. I replaced the fuse and it still didnt work so I ended up taking the center of the steering wheel off and found the metal plate on that part and it has broken of in a spot where the two pieces connect when you push. Thanks
Old 04-07-2010, 11:44 AM
jdl jdl is offline
Re: No horn!!
Hey, good job. Sounds like you got it going your way.
