Go Back   Automotive Forums Car Chat > Kia > Sportage
Old 04-04-2010, 01:59 AM
dyerbad dyerbad is offline
Flashing hold and Check Engine Light...
I have read all over this forum that this is a pretty common problem. The Hold Light and Check Engine Light all the sudden started flashing on Thursday.
Was losing power and rough on take off Had it scanned and it came up with the Throttle Position Sensor and CYL #3 Misfire. Replace the TPS and the coil...
Drove it after the parts were installed and its fine up to about 55 Mph.. then it starts jumping like a misfire. The hold light and Check engine light are flashing again... any ideas?? This car has had a new timing belt and transmission... however sat for over a year before I got it and start driving it. It has been great till now...
ETA: Got some codes this morning...
P1121, P0101, P0122, and P1624.. Husband is thinking it may be the MAF sensor... also it has Ford Sparkplugs, will be replacing with Factory recommended spark plugs at the same time
Old 04-06-2010, 07:21 PM
LMP's Avatar
LMP LMP is offline
Re: Flashing hold and Check Engine Light...
1624 says "a code has been sent..."
The rest is relevant with MAF and TPS....but begin with cleaning the sensor contacts, sockets; long time with moisture helps bring those problems. I would not go as fas as suggesting soldering the wires directly to the sensors, as some suggest, but do clean and test.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
