Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 04-03-2010, 11:35 PM
Gils Gils is offline
2002 front end noise
I have a noise coming from the front end. It increases with speed not RPM. It sounds like the noise a large 4WD truck tire makes, only not quite as loud. It is worse when steering to the right than the left. I have new tires, brakes and allignment. Has anybody else had this or can guide me in the right direction?
Old 04-03-2010, 11:41 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: 2002 front end noise
Sounds like a left front wheel bearing.
If you jack up the front of the car with the trans in neutral you can spin the front tires by hand. Hold on to the coil/spring with one hand and spin the tire with the other. You should be able to feel the noise your hearing.
