Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 04-03-2010, 04:40 PM
hyper31 hyper31 is offline
95 Tranny Problems
I have a 95 T-Bird with the 4.6 auto tranny. It doesn't shift. I can put in reverse, neutral, Drive, 1, and 2. all of that works, it just doesn't shift automatically. If I have it in drive and rev to over 4000 r's then let off, it will shift into second but won't go any farther then that. Also it will not shift back into 1st unless I come to a complete stop. Any ideas on what is going on? I really don't want to stick a ton of money into it. Thanks in advance.
Joe
Old 04-03-2010, 10:36 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: 95 Tranny Problems
I'd start by looking into the condition of the ATF and proper operation of, or replacing (even as a preventative maintenance measure) the MLPS (driver side of transmission body) and the TPS (on the throttle body). The PCM uses data from these to determine shifts.
If the ATF is discolored and smells burnt, it needs to be flushed with fresh Mercon V ATF.
If the ATF is in good condition and the sensors are working properly, than it is probably the shift solenoids. They are pretty easily replaced once you remove the transmission pan.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
