Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 04-03-2010, 06:57 AM
juicedcutlass juicedcutlass is offline
replaced intake gaskets now it wont start
welp i replaced the intake gaskets on my 95 cutlass ceira, 3.1 engine, now it wont start..
when i did the job i layed out the push rods in order so i wouldnt mix them up, i didnt remove any plug wires,when i go to start it ,it makes sounds like its out of timing and then it will just crank and crank, and then it seems like it wants to start then nothing,i checked the fuel rail and when i press the valvefuel does come out,i checked the plugs none of them seem wet ,all pretty much look dry, im at a lose ,like i said i didnt remove any wires and everything worked fine up in till now,
Old 04-03-2010, 08:49 AM
maxwedge maxwedge is offline
A990 racer
Re: replaced intake gaskets now it wont start
Welcome to AF, recheck your work, are the injectors pulsing, any connectors not reconnected, got spark?
Old 04-03-2010, 07:46 PM
thank you maxwedge..
i check the plugs again and noticed they were firing were spark was weak, i guess they were fouled out after all, went to auto zone grabbed a set of plugs and she fired right up,i took some pics of the inside of the intake what a mess oil and antifreeze oh man gook heaven !
heres the link if anyone whats to peek...
http://pbckt.com/sy.wCc
