Old 04-03-2010, 02:46 AM
Diablue Diablue is offline
Suggest an amp
For 2 cheap VR3 400watt max subs. Budget is cheap. Under 100 bucks.
I want to run both of them near or at 400watt if possible.
Appreciate any help
Old 04-03-2010, 11:37 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Suggest an amp
400 watt max is usually 200 watts RMS. Any amp that puts out 400-500 watts RMS at the right ohm load will work
Old 04-04-2010, 04:11 AM
Re: Suggest an amp
I dug up the paper that came with one of the VR3s. These are the specs;
-400 Watts Max Peak Power
-40 Watts RMS
-35 to 2000hz freq. response
-1.5" ASV Voice coil
-Impedance 4 Ohms +/- 15%
-Sensitivity 87db 1W/1M Minimum
I dont want to overpower them and cause damage. would a 200+ watt rms cause damage?
Old 04-04-2010, 07:12 PM
Audio Guy
Re: Suggest an amp
40 watts RMS ... is that right ? that's not much real power
Old 04-05-2010, 01:51 PM
Re: Suggest an amp
Yeah thats right. I know they aren't powerful but I do want to get some sound out of them for now. I hooked them up to my radio which is 60watts max, turned it all the way up and barely had any sound.
Old 04-06-2010, 06:29 AM
Audio Guy
Re: Suggest an amp
you can run a fairly low powered amp, like 50-75 watts per channel for them
Old 04-07-2010, 03:06 AM
Re: Suggest an amp
that seems kinda odd. i looked around on youtube and found a vid review of my vr3s. it seems they can handle 200watt rms, but would they be damaged by that wattage over prolonged usage..
edit: how would this be for them? http://www.sonicelectronix.com/item_...oss+CX150.html
Old 04-07-2010, 04:06 AM
metroautoshop metroautoshop is offline
Re: Suggest an amp
this is a common problem you face when u buy cheap....i myself used to buy things cheap but most of them turn out not to be so good at all and since then i starting buying everything branded everything expensive and live happily ever after hehehe lol
