Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 04-02-2010, 09:02 PM
kilroy357 kilroy357 is offline
97 ram transmission wont engage sometimes
4 wheel drive, shifter moves but tranny doesnt engage sometimes, it doesnty slip or anything out of the ordinary. was wonderin if yall had any tips for me to look at.
Old 04-03-2010, 10:31 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 97 ram transmission wont engage sometimes
Some Mopar transmissions have torque converters that leak down overnight. Because they fill only in gear(real slow) and in neutral.
I used to start the engine then put the gearshift in neutral until the engine oil pressure gauge showed good pressure, after about 3 seconds, then drive away in my '92 W250. Drove it like that for 4 years without any problem.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 06-02-2010, 11:35 PM
bratt bratt is offline
the engine oil pressure is not the transmission oil pressure though!
