Go Back   Automotive Forums Car Chat > Mercury > Mystique
Old 04-02-2010, 08:27 PM
timmyb74 timmyb74 is offline
99 Mystique turn signal/flashers
Neither the turn signals or emergency flashers are operating on my 99 Mystique. Is this usually the flasher relay? Where is it located?
Old 04-02-2010, 10:58 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Re: 99 Mystique turn signal/flashers
Yes it can. Check in your owner manual. If you don't have it, you can download it.
It could be also a bad contact in emergency flashers switch. Cause this one controls both turn signal and flashers. At least, does the brakes lamp work?
If it's the problem, try to hit the 4 way switch location. It may help.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 04-04-2010, 10:18 PM
scottman25 scottman25 is offline
First do the simple thing and check your fuse panel. under the dash left side of the brake pedal. could be something that simple. if thats not it. you are going to have to take the plastic housing off the steering column. Not hard to do. there are two phillips screws on top and three on the bottom. take the shroud off, then on the bottom left side of the steering column will be the relay for the flashers and turning lights.
Good luck, hope this helps you
Scott
Old 04-25-2012, 09:07 AM
Invisions Crew's Avatar
Invisions Crew Invisions Crew is offline
in my 2000 mystique all i did was take off the steering column housing from the top, then on the left side was what i call the multipurpose switch, you can remove this by pressing a little button down and removing some cables. then underneath the switch there is this little cube looking box plugged into the bottom, that is your relay, pull that out and take it to a ford dealership and they can get you a new one for like 25 bucks. after that put everything back together and it should work. i went without turn signals forever before i figured out how simple of a fix this is.
