Go Back   Automotive Forums Car Chat > Pontiac > Aztek
Old 04-02-2010, 12:28 PM
crazydriverz crazydriverz is offline
how to access the fuel sending unit on 03 aztek
Old 04-02-2010, 01:16 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: how to access the fuel sending unit on 03 aztek
Drop the Fuel tank.
Old 04-05-2010, 02:42 PM
well i was hoping there was an access door under the seat or the trunk area. i guess not, thank you
Old 11-17-2010, 07:40 AM
gjhunter01 gjhunter01 is offline
It is really not that bad a job to drop the tank, takes about 45 min. Jack up the rear of the vehicle, remove the 2 strap bolts and lower the tank with a floor jack. You can leave the filler neck attached and the tank will tilt toward the pass side. Then disconnect the 3 fuel lines, 2 elec plugs, and twist out the sending unit lock ring. Greg
