Go Back   Automotive Forums Car Chat > Ford > Super Duty
Old 04-02-2010, 08:05 AM
ajoseph3 ajoseph3 is offline
2004 f350 6.0l
71,000 miles. No chip. 5sp manual. I wasn't have any problems until after I came back from a week long business trip where I had my truck at the airport parking. It started up just fine, and seemed to run just fine, after the 40 miles highway drive, I got off the highway, stopped at a light, then as I started going again, the truck started "chugging" a bit and I noticed that I was blowing quite a bit black smoke, (which has never happened like that before), As I continued to drive the chugging would stop once the turbo would engage. The chugging was worst in the low RPM's and mainly in gears 1 to 3. That was 4 days ago, the last 2 days the chugging didn't seem to really be there, but I have pretty much constant black smoke in any gear, at any speed, at any RPM, but obviously more so once the turbo engages. There doesn't seem to be a lack of power at all, and besides the smoke, it seems to be running fine. I got an oil change on day 3; 800 miles before it was due, and the shop said that the "old" oil was very clean. Any ideas or help would be appreciated.
Old 04-28-2010, 09:58 PM
fordtrucksonly's Avatar
fordtrucksonly fordtrucksonly is offline
Re: 2004 f350 6.0l
EGR valve is bad, the cooler is probably blown. EASY FIX.
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
Old 06-26-2010, 09:35 AM
othrhog othrhog is offline
Re: 2004 f350 6.0l
The vanes are stuck on the turbo. Caused by carbon build up on them. This turbo needs to be HOT 1000 deg to burn off. I had same problem with my 03 and set the brake and held power till 1000 deg for a good 5 min's Problem solved. Garrett confirmed the fix and said it was a problem.
Old 06-26-2010, 11:26 AM
Re: 2004 f350 6.0l
Are you kidding me?! 10k degrees will melt a motor down like nothing! I dont even know how you would get one that hot considering with 190cc injectors and 66 charger im at around 1400 degrees max EGT. Also the charger wont make smoke, just lack of boost. I promise the EGR valve is bad, i work on these trucks EVERYDAY.
DO NOT LISTEN TO THIS GUY. 10k Degrees will melt a motor!
'95 Ford F-150
Ford Racing Pride
General Motors who?
Old 06-26-2010, 11:47 AM
Re: 2004 f350 6.0l
OUCH DUDE... I work on these everyday too..I own a diesel company.. Problem is i don't type well... I meant 1000 deg... Sorry is this how this forum welcomes new users...???????????????????????? Maybe are you sure 10000 deg or did you mean 1000 deg...Give me a break.... Hope you dont own a PSD cause you act like a Dodge owner Also my EGR was not hooked up when I had same trouble it WAS the vanes Garret confirmed this fix after I did it
Old 06-27-2010, 10:34 AM
Re: 2004 f350 6.0l
It still wont black smoke from vaines, just wont boost, or It will bog. Dont use the "I dont type well" excuse, You dont typo something twice (numbers included). I own a Diesel shop too, Fancy that. Either way your not helping his problem, your adding to it. I will bet money that the EGR valve is bad. The Vaines do have problems, I'm not arguing that. Thats just not the problem at hand.
Oh and Welcome to the forums.
And I drive a fairly mean 6 liter.
'95 Ford F-150
Ford Racing Pride
General Motors who?
Old 12-15-2010, 04:08 PM
mustangman02232 mustangman02232 is offline
Send a message via AIM to mustangman02232 Send a message via MSN to mustangman02232 Send a message via Yahoo to mustangman02232
Re: 2004 f350 6.0l
stock will defuel if it sees low boost so that wont smoke, could be the EGR valve, turbo or injectors as a way to start, im going to fix my EGR (when it goes, want to see how much tortue i can give the 6.0 first) the correct way, by throwing it in the scrap pile.
BTW, even with my tune i very rarely see over 1000* EGT
2004 F350 6.0 4x4 auto SRW
SCT X3 with innovative tunes, autometer boost/trans/pyro, AFE stage 2, MBRP 4" no muffler or cat, EGR delete, ARP studs, 8' fisher MM2, misc appearance
90 F350 7.3 IDI 4x4 SRW (sold)
bolt on 02 mustang 232 4R70W vert (sold)
built 88 toyota pickup (sold)
bolt on 92 camaro LO3 TBI (sold)
