Old 04-02-2010, 07:33 AM
barrelboy barrelboy is offline
Question 98 Lesabre just turns off
I have a 98 Lesabre and when driving it just shuts off. I cleaned the corrosion from the positive battery connection. I even cut open the red boot and cleaned between two of the three connections. The connection to the battery is tight. When drivind it just turns off as if the battery gets unplugged. I have noticed in the past that when I start the car the alternator gage is low for about 4 seconds then jumps right up to right before the red mark. After it dies it will start right up no problem.
Any ideas would be helpfull.
Thanks
Old 04-02-2010, 01:26 PM
jcc3inc jcc3inc is offline
Re: 98 Lesabre just turns off
Sir,
I have had the "just turns off" problem with o ur '97 and my '91. The turn-off ocurred when the unit was warm, up to temp. It turned out to be a bad crank position sensor. If it sat for a while and cooled down, then it restarted and ran well for a time.
Regards, Jack C.
Old 04-03-2010, 07:04 AM
big white bufflo big white bufflo is offline
if you have ever been driveing down the road and felt your car hicup and wondered what was that !!! then blew it off as a freek it could be the crank position sensor they are known to go bad on these mine went bad at 145000 . are there any codes and how many miles are on this car take it to autozone they will scan it free then get back with us
Old 04-05-2010, 09:20 AM
The car has 139,000 miles on it. Also the check engine light is not on so I don't know if it is throwing any codes. I'll check with autozone.
Old 04-09-2010, 01:02 PM
jpawl jpawl is offline
Originally Posted by jcc3inc View Post
Sir,
Regards, Jack C.
This ^^^^^^^^
be careful changing yourself.You need a special tool for the balancer to get to the sensor itself.
