Old 04-01-2010, 11:55 PM
y13supio y13supio is offline
2.5L to 3.3L engine swap
i have a 1992 dodge caravan with the 2.5L engine, would a 3.3L out of a 1990 plymouth grand voyager work in my van?
thank you, Jon
Old 05-14-2010, 11:58 AM
mike7051 mike7051 is offline
Re: 2.5L to 3.3L engine swap
yes it will fit but considering the age of the van i would suggest just buying one with the 3.3, youll need the ecm and engine wiring from the 3.3 as well as the radiator trans everything its just not worth it...
Old 05-15-2010, 09:08 AM
thank you for your input. i'm actually looking at a 3.3 in a beat up voyager. the only problem is when you push down on the gas pedal to hit passing gear, the motor doesn't die but it falls on it's face until you let up on the pedal then it runs fine again. any ideas?
Thank you, Jon
