Old 04-01-2010, 07:56 PM
glc4123 glc4123 is offline
axle nut size
yes, does anyone know what size the axle nut is on a 1997 pontiac gp?
Old 04-01-2010, 10:14 PM
doctorhrdware doctorhrdware is offline
Re: axle nut size
I think that it is a 36MM nut?
Old 04-02-2010, 11:16 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: axle nut size
It is 34 MM. Sockets can be purchased @ most big box parts stores.
Old 04-03-2010, 10:08 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: axle nut size
My '97 GTP has a 36mm axle nut.
Timeslip 08/12/06
AF Community Guidelines
Old 04-05-2010, 03:52 PM
Brent S Brent S is offline
Re: axle nut size
I used a 1 3/8" on my '99 GTP axel nut, and my friend also used it on his '99 SE........it worked PERFECTLY. When you calculate the mm conversion (using the 1 inch = 25.4 mm), it works out to 34.925 mm.........so, if it is, in fact, a 36 mm nut, that probably explains why my 1 3/8" socket worked so well (perhaps even better than a 36 mm socket), as it was a nice "snug" fit on the nut, which is what you want in that case.
Plus........a 1 3/8" socket might be easier to find than the metrics.
-Brent
'99 GTP
