Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 04-01-2010, 01:32 PM
italie italie is offline
Ping / intake backfire on 350
Just wanted to gather some opinions on a recent issue with my '95 Yukon.
Background:
Last weekend I replaced the exhaust from the manifolds all the way back. new stock cat and Napa soundmaster muffler. (As opposed to no cat and a flowmaster).
At that same time I replaced the plugs, going from Bosh Platinum Plus (HR9BP) to Delco CR43TS gapped at 35.
(If you are wondering why I downgraded everything, truck was a little too loud for my daughter, and the plugs were $5 a plug cheaper..)
Issue:
Ever since, my car has run a little rough, almost like a miss. Fairly smooth in park at idle. At idle in gear is rough like it's missing on a cylinder, but never stalls. Rough running continues up past 40, but isn't so noticable beyond that.
Every now and then at low speeds, or when laying off the gas around turns I get a pinging/backfire throughthe intake. happens once or twice, doesn't do it again for 5-10 minutes. Doesn't seem to prefer cold/warm.
Question:
Could these Delco plugs be causing the issue, or could it be the recent addition of a cat and more restirictive muffler? Is 35 a decent gap? IAC is a month old, all the plug wires appear snug, no vaccuum lines appear cracked/unhooked. Curious if I should pend the extra $40 and pop in another set of platinums, or if the issue is cat/muffler addition related.
Old 04-01-2010, 07:38 PM
maxwedge maxwedge is offline
A990 racer
Re: Ping / intake backfire on 350
If you feel a definitive miss at idle, started only after doing these changes, I would focus on a possible bad wire, or even a cracked plug, recheck what you did.
Old 04-01-2010, 09:43 PM
Re checked them a couple of times, even swapped 6 of the 8 platinums back in. (lost 2) Still present. It's not so much a definitive "miss" as pulling a plug wire, but feels similar.
I could see it possibly being wires, improper gap @ 35, or maybe even timing. I'll be checking those tomorrow.
Old 04-02-2010, 04:48 AM
yukon6inchlift's Avatar
yukon6inchlift yukon6inchlift is offline
almost every time i change plugs at least one wire breaks on me it seems. i agree prob a wire or 2
