Removing door panel
Hi all,
I have a rattling noise coming from the drivers side door, I'm almost certain that the speaker has come loose somehow and is rattling around inside the door panel. How do I remove the door panel so I can tighten up the loose speaker? Thanks, Chris
Chris S. 2001 Bravada Platinum Ed. 1992 Beretta GTZ |
Re: Removing door panel
Thanks to Pawl
Here is EXACT procedure for removing door panel... You'll need a specialty tool, a Trim Pad and Garnish Clip Remover, should be able to get one at your local parts store. Remove the inside door handle bezel. Remove the window regulator handle, if equipped. Remove the power accessory switch mounting panel, if equipped with power accessories. Remove the trim panel armrest screws. Use the Trim Pad and Garnish Clip Remover in order to release the door trim panel retainers. Remove the door trim panel from the door. |
